Matrix Reloaded How To by AHAC
All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules.
Closed Thread
Old 21-09-2004   #26
Smile
THANK YOU gsmsikar for your reply.
from,
pretty
pretty_1963 is offline
Old 11-10-2004   #27
Angry
Hi all great info
But can anyone still tell me if they have managed to update using IBM R40 XP laptop cause ive tried everything and it does not work.
Is there a reason to use the mr_pcmciap driver on the website as they are not english versions or can u use the pcmcia driver that comes with xp i have treid both but does not recognise cam mr1.04tb any help would b welcomed
onelouis@hotmail.com
louis2 is offline
Old 12-11-2004   #28
rolfw's Avatar
Real name: Rolf
It does not work with all laptops, yours is probably one of them.
Rolf
rolfw is offline
Old 28-11-2004   #29
matrixcam
how to load matrix cam via pcmcia slot PC
bouhatunis is offline
Old 08-12-2004   #30
Thumbs up Suivre ce lien
Here you will find all what you need
http://www.matrixcam.com/laptop.htm
tunisianspring is offline
Old 08-12-2004   #31
YOU will need this file
To procced with the upgrade of your matrix you will need a file like this
2.14.upd (to use in the 17th step) in the link
Its easy and it works (tps(full bouquest) ok, polsat ok, tv cabo ok)
Old 08-12-2004   #32
Wich matrix version you have
we need to explain wich matrix version you have.
Old 14-12-2004   #33
There is a prog named MRFM= Matrix Reloaded File Manipulator. Where can I find it?
Stickan is offline
Old 18-12-2004   #34
hello i have put new version to my mr it was working fine before i had 2.14v i want it to change it to 2.13 so i can use a card with it cause the first version was revolution 2.14 and i have mr reload any way when i put it in my receiver it keep showing me initializing it want do anything or give me the new version i put i did this with cas 2 studio 1.4.7 can anyone help please thanks
jacinto is offline
Old 20-12-2004   #35
I don't intend by this to make free advertisement to "duolab" guys, but I have tryed many systems for programming CAMs and CARDs, and I found the Philosophers' Stone in their latest programmer, the CAS Interface 2 + Add-on.
You can very easily and fast program various cams (no need for fun-cards) and with the add-on you cam program and repair Various Cards.
AlfaSierra is offline
Old 20-12-2004   #36
To JACINTO, if you have a MR cam with MRev soft in it, you will not be able to read a card.
On a MReloaded cam, by experience, I can say that MR1.071 was the last soft to read well cards.
I am receiving Cabo right now using that config:
MR1.071 + BlueTit card with TMB2.8 (the latest)
Old 13-01-2005   #37
Lazeerider's Avatar
good tutorial, almost perfect. But how can we edit keys with the fun card? In most MR versions the receiver doesn't let us enter into the CAM's keys submenu. Whenever we choose a provider the CAM initialise itself instead of opening the keys.
Lazeerider is offline
Old 13-01-2005   #38
guiri's Avatar
Lazeerider - you can make your own firmware files with new keys and then put them onto fun card files if you want. Search for sep on this forum eg.
http://www.satellites.co.uk/php-bin/...&highlight=sep
guiri is offline
Old 17-02-2005   #39
adn
Hi Rolfw,
I just read your info about upgrading keys with remote control to Matrix cam revolutions. But, unfortunately, I couldn't find HOW TO PUT KEYS CODES WITH REMOTE CONTROL. I have a KAON decoder KSC 500H and MRV 2.16. Thanks for helping.
Regards.
adn is offline
Old 22-02-2005   #40
adn
Rolfw, could you have a look at this.
http://www.satellites.co.uk/php-bin/...ferrerid=77247
From,
adn
Rolfw
Originally Posted by rolfw
Have asked AHAC if I can upload this and he happily agreed.
I have opened the file and it is shown in the post below.
adn is offline
Old 02-03-2005   #41
hello
can anybody help me
I want to upgrade the version vith cable rs232 from laptop
how to do this
fantazma is offline
Old 06-03-2005   #42
Talking Jacek
Hi to all of you.
I am first time on the forum but I have bought my Matrix Reloaded Cam two years ago and from that time a haven't updated it, only manually with remote control so I know a little bit about it. All I want to know is what is the UCAS and Windows updater 1.3 (I know Windows 98 has version 1.3). I got some information from http://www.neptunboard.com/get_topic.asp?FID=16&TID=738&DIR=P but I still want to know more. And can I use a dummy card to program my MatrixRd.
Which one is better with or without extension power supplay.
What is different beetwin MtrReload and Revolution and which CAM is the best for today.
Thank you for any answer.
Jacek from Poland
Jacek is offline
Old 06-03-2005   #43
My System: Echostar 2200 IBM T40
Hi there,
I tried to upade the firmware of my MRV with a Fun4 as showen in the "complete mr guid" but when I insert the first fun card 4 and after the message "Performing smart card download..." instead of the message "Download card completed" or "Insert card 2", I see this message "cable removed or baudrate too high for this STB. Please try again." I tried many times but always the same message
Could you help me?
Is it possible to update MRV firmware with Fun4?
Is it the same flash file for MR and MRV?
if not, did you know where can I find a flash file for funcard4 to update a matrix revolution card?
Thanks in advance.
For information:
I use the MRV for Echostar2200 2ci and Fun4 with an "Infinity USB".
Deder76 is offline
Old 10-03-2005   #44
My System: MAT
Matrix Mci-5000
help i need software receiver MATRIX MCI-5000
waleed_oly@hotmail.com
WALEED_OLY is offline
Old 14-03-2005   #45
Cool
Jacek[QUOTE=Deder76]Hi there,
Try from www.matrix.com
You can get some information from there
Jacek is offline
Old 03-05-2005   #46
I have a desktop pcmcia and cannot install the file dreammagic.inf although I can see it in the file.Any help please?
GURUJI is offline
Old 13-05-2005   #47
Hi just wandering if this process will work on PC DVB-S TV cards or is it just for the boxes
lean_moha is offline
Old 26-08-2005   #48
does anybody who a hex files for dream satellite philippines
jinggoy34 is offline
Old 30-08-2005   #49
My System: Liberty reciever with motorised dish
Help with MR Cam
Can anyone help?
I am relatively new to the satellite scene and have got a Matrix Reloaded cam which was sold to me working perfectly and allowing me to watch all the Multivision channels, however after about three months all channels disapeared.
The sat guy would re-connect me but at a charge of £60....
What do I need to do and how?
Does anyone know the answer?
Many thanks,
Adam...
Adam0 is offline
Old 10-09-2005   #50
Hi
I have echostar ad 3000 ip viaccess + matrix revolutions cam (actually it is a magic cam updated to matrix revolutions cam).
Now I still use MRV 2.22 and I want update to the last version. Unfortunately I don't have programmer for cams only programmer for cards (USB Infinity). It seems that it is possible to update matrix revolutions cam with fun card or with laptop!!!
Can you please tell me if it is true and how to do it?
Thanks for reply.
PS: I have fun card 2
whatsmydestiny is offline
Closed Thread
ahac, matrix, reloaded
Similar Threads
matrix reloaded cam martyn Matrix Reloaded, Revolutions and CAS interface 20 28-08-2006 01:37 AM
Matrix Reloaded Cam - How to update user909090 Matrix Reloaded, Revolutions and CAS interface 54 22-08-2006 08:29 AM
Matrix Reloaded CAM & The Fun Card user909090 Matrix Reloaded, Revolutions and CAS interface 2 01-07-2005 02:51 PM
Matrix ReLoaded .... please help me understand it war head Matrix Reloaded, Revolutions and CAS interface 25 03-01-2005 10:03 PM
Matrix reloaded or stay as I am ? redrooster Matrix Reloaded, Revolutions and CAS interface 23 26-05-2004 08:26 PM
