Mr not work with North America Nagravision?All information about the Matrix Reloaded and Revolutions CAMs, plus the CAS interface for programming MMs, MRs and UCAS embedded modules. | |
| Regular Member Join Date: 28-02-2004
I just bought a matrix reloaded card to use with north america nagravision (dishnet/expressvu) I typed the keys in the menu provider id 0001/0801 for dishnet/expressvu and nagra keys still says scrambled on screen, i also took the atmega128 which was programmed for north america nagra put it in the matrix reloaded cam it said no available card for this cam (what does that really mean?). It rejected north america nagra and even the atmega card (which is like a rom3 nagra card which should atleast let it display info about it). | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I am having the same message displayed with the matrix and Titanium card in my Coship receiver, this may be more to do with Receiver/CAM communication. | ||
oh you got the same message, i think any receiver you get the same message "no available card for this cam" I think it has to do with the provider id 0001/0801 not added on the list as acceptable provider which means this program probably totally rejects north america nagravision which it shouldn't. | ||
| Regular Member Join Date: 14-02-2003 Location: home
| I just read this thread, the reason NA Nagravision does not work on the Matrix Reloaded is the fact that NA nagra uses mecm mecm2 which it has been implemented for the European providers (provider ids 4801,4901,Polsat,cabo,D+) The 4801 fix that the TMB V2.2 uses to put in the MECM decode keys is the same. This is the format the keys need to be input for Dish,Globe and Express. This is the same format used in the file for the PCI Cards. N1 00 00 00 00...up to 64 N2 00 00 00 00...up to 64 E1 00 00 00 00...up to 64 I just checked TMB v2.2 and the only one implemented is the Provider 4801. TV Cabo it uses the above format. I have not been able to find a program that allows the NA provider ID to be added in this format. I am not a programmer so I cannot help. TMB V2.2 allows 4801 to be changed, but you cannot change the CAID. If the CAID could be changed, I think NA ID's could be added to the Matrix Reloaded. In place of the Conax if it is not used. hope this helps | ||
| america, nagravision, north, work |
Similar Threads | ||||
| Globecast / DFH 1,2,3,4 Turkish Ch in North America | Rodrighez | Keys and Key editing | 26 | 28-10-2008 09:34 AM |
| Transponder update October 2007 | Satdude | Transponders & channels | 666 | 25-10-2007 11:44 PM |
| notes from north america | frenchhomer | Sky Digital (BSkyB) and Astra 28.2 East General | 1 | 10-02-2004 10:56 PM |
| MR keys for North America ????? | 7777user7777 | Keys and Key editing | 1 | 02-02-2004 12:42 AM |
