satellite programs in english | |
| Member Join Date: 04-06-2007 Location: derby
My System: gb sat |
hi ive been searching for the name of a site it lists the tv programs thats available on the various satterlites.it sounded like lyngaurd?any help please.also if i switch to a twin lnb what programs could i expect to receive?as you can tell i'm a complete novice. regards leadshot | ||
| Member Join Date: 28-06-2007 Location: North West ENGLAND , Rochdale OL10
My System: TELEVES rds 7254 DVB 2000, motorised 1.2mtr diseqc | u are probably looking for lyngsat.com that has a good list . | ||
| The Following User Says Thank You to simon p For This Useful Post: | leadshot (17-08-2007) |
| | #3 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. |
A 'Twin' LNB will give you no more tv programmes than a standard single output LNB. It is designed so that you can run two receivers from one LNB, or a _Sky plus box which has two receiver built in. A 'Dual' or 'monobloc' available in 6 degree and 3 degree varieties will enable you to receiver two satellites from the one LNB with the sats 6 degree or 3 degree apart respectively. and Yes it's lyngsat.com that you want, there are also lists on flysat.com and _http://en.kingofsat.net/ there may be others also. I have found that sometimes one site doesn't contain the most up to date info, and it's worth checking one of the others. Lyngsat I have found though is the easiest and clearest to navigate. | |||
| The Following User Says Thank You to Robbo For This Useful Post: | leadshot (17-08-2007) |
