HELP -Hoover Handle Lock Release
Discuss your wife's objections to the fifth dish going up or your concern that there's far too little violence on the box these days. You can also introduce yourself here or just chat about anything. Remember, no keys or files allowed.
Old 10-09-2007   #1
Rob
Super Nutty Mod
Rob's Avatar
My System: Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
I have got a Hoover Dust Manager Cyclonic cleaner and I have messed up the Handle Lock Release, the part were you stick your foot to release the handle when you start hoovering. (See pictures below or ask the wife)
Does anyone know how to fit the handle lock release together, with a picture if possible because I'm knacked as the handle will not catch on the catches and keeps falling over.
This type of handle lock release is very common on Hoovers, and I know it seems very easy but I just can't seem to get it.
Thanks a million for any help.
Rob is offline   Reply With Quote
Old 12-09-2007   #2
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos there's no room for dishes here... :(
The Sleepy Hollow pollracle has spoken!
Have you tried a hammer?
I don't know much about toy vacuums, but I guess the spring that holds the latch in place has come loose, so you might need to open it up and us a bit of Areldite to repair it if possible, or just take it to a vac repair shop and see if they have anything you can part-ex it with...
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
(though the latter no longer fits due to my ever expanding waistline!!!)
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 12-09-2007   #3
Mod and septic resident
Channel Hopper's Avatar
Sounds like there is a clip that has come off inside the cover
There is (on the photos) some sign claiming 'important'. Was it ?
If it falls over then at least you can work with it to hoover up the dirt. Can you not prop it up in a cupboard when not in use ?
Channel Hopper is online now   Reply With Quote
Old 13-09-2007   #4
ASBO Club Team Spokesmen
Yeshi's Avatar
My System: Dm500, TM9100, Pace Sky+ box, 1M Dish. Motect 2100.. 43Inch Plasma, Wii, PS2.
why is your hoover eating your glasses?? is that all remains of the mrs??
Originally Posted by 2cvbloke
But I do vacuum that patch a lot, it's just the flash that makes it look like 5h1t...
Yeshi is offline   Reply With Quote
Old 13-09-2007   #5
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
In the olden days, Hoovers had a spring loaded plate inside the cover which pressed against the edge of a metal disk which was attached to the handle and turned with it. The disk had 2 notches so that it worked like a ratchet so it allowed the handle to swing to the upright position but you had to move the plate down (by pressing the pedal) in order to swing the handle down. Over time the corners wear off the notches and does what yours is doing.
pgh13 is offline   Reply With Quote
Old 13-09-2007   #6
Rob
Super Nutty Mod
Rob's Avatar
Originally Posted by 2cvbloke View Post
so you might need to open it up and use a bit of Araldite to repair it if possible, or just take it to a vac repair shop
I did that and still the same, I think I'll cheat a bit and take it to that vacuum repair shop.
Sod's law that the electrical shop that could have fixed this is only across the road, but it shut down last week.
handle, hoover, lock, release
[IMG] code is Off
