Digisat Pro... | |
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | no it doesn't tell you what satellite you have aligned to, only just a signal strengh bar on an lcd screen for anything like satellite NIT readout you will need a meter like the satlook micro, horizon hdsm v3 or wolsey/lacuna meter | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Can't find that model on the emitor site, have you got the spec?
__________________ | |||
| | #5 | ||
| Regular Member Join Date: 09-09-2008 Location: Republic of Georgia
My System: Skystar 2.3i 7W-5E-13E-25.5E-26E-36E-40E-42E-53E-75E-90E | Mine also does not. And btw, it's not a good investment I believe. Does same, as cheap finder. | ||
| | #7 | ||
| Member Join Date: 20-05-2008 Location: n w england
My System: dream5000 v box 1metre motorised | Try the Satcatcher exel TV. Its got all the European channels in it, got a speccy, and will show picture and sound on the FTA channels. It also drives a diseqc motor! Comes with a handbook in english - well Yorkshire English actually - and a CD to write or edit the channel plans. We use them for all our work, including motorised. | ||
| | #8 | ||||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | OK, thanks, but that isn't the Digisat Pro the original poster was talking about, yours is a Swires meter and probably quite a bit more expensive.
__________________ | ||||
| | #10 | ||
| Regular Member Join Date: 28-05-2007 Location: Terre Rouge, Mauritius
My System: 1.2 m Eurostar dish KU band W3A, 3.7M C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 3.4m prodelin prime fibreglass on Intelsat 906 64 Deg E STARTRACK NC707 Plus, Skystar 2 DVB card | don coolman. why is must be the 22khz ON for KU universal LNB to work on this meter. Is this normal? For C band no 22KHz is needed. | ||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | C-Band LNBs are single band, whereas a Universal LNB is dual band and uses a 22Khz tone to switch to high band.
| | #12 | ||
My System: 1.2 m Eurostar dish KU band W3A, 3.7M C band on the arc from Atlantic bird3 to Measat 3, 1.5 m offset on PAS 10 KU, 70cm Offset on Eutelsat W2, 3.4m prodelin prime fibreglass on Intelsat 906 64 Deg E STARTRACK NC707 Plus, Skystar 2 DVB card | Thanks I understand now. Higher frequencies (LO 10600) needs that band switching. | ||
