Marley garage roof - Asbestos ? | |
Marley garage roof - Asbestos ? Any 'more mature' builders out there ? I am just about to take a Marley 'medium' garage apart. (Design number 862247), as it has been damaged by vandals. The roof consists of corrugated panels, approx 6' x 4, which look like concrete, however because the garage is early 70s,I am suspicious there may be a layer of asbestos within them. Marley disappeared from the construction scene years ago, and I cannot findanything useful on the internet, the council have advised I get in touch with a specialist, however the only one that has replied is in Oxford and is asking for a sample for analysis. Before I break off a part, does anyone have knowledge/experience of this type of garage, and whether there is a difinitive yes or no to the construction ? Thanks
__________________ There is a very fine line between "hobby" and "mental illness" | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I've got a similar roof on my garage, not Marley though. I replaced a cracked panel with one from a neighbour's garage being dismantled years ago (before H&S concerns). As the asbestos is embedded in cement, it should be safe to remove, but if you do any hole drilling (as I did) then wear a mask. Unfortunately this didn't stop a piece of fibre catching me in the eye, necessitating a trip the hospital for removal ![]() Llew | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | Could be worth asking on diynot.com | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
My experience is similar to Llews and my local tip would only take the panels if they were sealed inside giant polythylene bags and left in a special area but that was 20 years ago so the regulations may be different now. It is more than likely that there is asbestos built in as it was the fibre that gave the panels their strength. In the 70's there were allsorts of asbestos material available. I remember a rawlplug product which was asbestos fibre and powdered PVA which you mixed with water then inserted into a hole drilled in the wall, you then screwed in your wood screw which would never ever come out again. So care needs to be taken mask safety glasses etc.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #5 | |||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | They are 'asbestos reinforced cement sheets', there is about 6% asbestos fibre evenly distributed throughout the structure. A couple of reasons for using asbestos is it's great tensile strength and the strong bond that it develops with the cement. It also has very good filtering properties which helped with the manufacturing process. Rarely mentioned but I think most beer was filtered through asbestos filters at one time.
__________________ Oldgeezer | |||
| | #6 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | The fibre not the eye I hope...
__________________ PaulR As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after. | ||
| | #7 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Nope, still got two of everything I should have - mostly working, although some of them a little worse for wear now | ||
| | #8 | |||
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | |||
| | #9 | ||
| Thanks I will now wear some protective clothing to dismantle the garage. Curiously enough even the guttering appears to be made of the same material.
| | #10 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased... The Sleepy Hollow pollracle has spoken! |
__________________ I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... Resident KIRBY Vacuum nut... ![]() | |||
| | #11 | |||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | Guttering and the associated fittings, especially the larger sizes, were big business, and also side cladding on industrial buildings. Pressure pipes were very big business, and were manufactured up to about 18" dia. being used for drinking water , sewage, gas, cooling water on power stations etc. Water storage cisterns were also manufactured in various sizes, an offshoot of this being garden planters up to about 5' dia. in a variety of shapes, clover leaf etc.
