Fibre optic LNBs the future? | |
| | #1 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. |
At the recent CAI trade show in the midlands, there were several fibre optic head end systems on display, mostly for use in larger systems, but still of interest. Of most interest was a prototype from Global Invacom, a fibre optic LNB, requiring a 12v supply at the dish, but otherwise only a single fibre back to the distribution point in the house/apartment block. The beauty of fibre optic over coax cable is the practically non-existent loss, less than 1db over 100m. This particular system can provide multiple feeds from a small switch, and by cascading, I believe that the system shown could provide 48 feeds or even more, ideal I would have thought for our big dish members in Astra fringe reception areas. this was only a prototype, but a working prototype, so keep a lookout for the finished product, was advised that it should be available in both LNBF and C120 format.
__________________ | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Any pointers there on terminating and/or splicing the cable runs? There are several methods of terminating the cable using different types of connector, but it will be a different ball game to coax (light losses etc.) Llew | ||
| Regular Member Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | soon,the invacom fibre opic lnb must hit the market,but i dont know prices yet,i think it could be very expensice 100€ or more for one lnb! is also a special wireless device like a sender,nesersary,on the backside of the reveiver? instead,of optical cable conection,30-40 m of optical toxlink cable,also aproixmently 100 € or more,seems to be,everything will be very expensice also,there are now products on the market,that coasts even much more,where you can transport,the lnb signals over the powerline like internet signals,in every household! but i have no further information yet,i only know,that this products exists but not for the "mass" market! | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes, there is a small switch unit, it can either go behind a receiver, or you can use it centrally, then send over traditional coax once in the home. It will obviously be an expensive alternative for the standard domestic installations, but has huge benefits onbig dish or large multipoint systems. They are also considering a terrestrial input for Integrated systems.
| | #5 | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | I did miss out then by not going along
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | LOL, had a chat with the guy on the stand and have to say that it was very interesting, can't wait to see the final product launch. Imagine only having to run one cable to a head end from the dish, with perhaps a 12v coax feed from a PSU , a combined cable if the cable manufacturers pick this up. I certainly see this as a boon for the system installer, near zero loss from dish to head end, means either negating the need for an IF launch amp, or facilitating the use of a smaller dish in sensitive locations. Must be an advantage for the big dish boys, as distance to the dish is no longer a problem, as long as there is a cable route.
| | #7 | ||
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Yes the benefit of no loss from dish to switches would be an advantage esp.. on long cable runs to the headend, it's a shame sub feeds were also fibre instead of coaxial where most of the signal problems occur
| | #8 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | It can be cascaded, so there could be fibre runs to the apartments. Have requested further and better information from Global, as I'm not 100% sure on the capabilities of the switch.
| | #9 | ||
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Any info you get, let us know Cheers
| | #10 | ||
| Member Join Date: 17-10-2004 Location: ireland
My System: tm dh 6800+250 hdd usb,tevion hdd/dvd recorder,tevion upscaler hdmi dvd player,philips 42 plasma hd,.beheringer psudo surround thru hi fi ,.. |
im wondering if theres a way of using fibre optics lnb into my tm hd 6800 or any digital box,..is there a way of converting an optical feed to a cable input [ f type] signal ,.come on you clever boffins out there,..that way it would lower the signal loss by using a short cable fed from the optical feed,..and we can use our current stb`s,..teddie,. ![]() ![]() | ||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes there will be when this is brought into production, but whether you'd want to pay the price for a standard installation is another thing altogether.
| | #12 | ||
My System: tm dh 6800+250 hdd usb,tevion hdd/dvd recorder,tevion upscaler hdmi dvd player,philips 42 plasma hd,.beheringer psudo surround thru hi fi ,.. | thanks rolfw,..just wondering if you heard anymore on the fibre optic converter,.how much and where to buy,.and also the f o lnb? cheers,.teddie. | ||
| | #13 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Hi teddie, no, not heard any more yet, but not really expecting to until late autumn, or possibly the new year, as it can be a long time between prototype and production model.
| | #14 | ||
My System: 1,25 Fibostop Jäger Smr 1224 Dual Axsis Echostar Dvr 7000 Monterey 140 Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesch for cband! | how the signal will be transmited,are the difrent solutions? when i must buy 30 meter of fiber optice light weave cable,that normaly used for souround receivers then its quite expensive 10 meter aproximently 30€! normaly incacom should have already realese this lnb,in tsi from april in spring,the told it comes out in summer time,now iam wondering,why nothing is here for the public to pruchase? | ||
| | #15 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Well I didn't see it until June Turok, but as I said, from prototype to production model can be a difficult road.
| | #16 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | If anyone wants to read the TSI article, you can download the pdf from - _www.tele-satellite.com/TELE-satellite-0805/eng/global-invacom.pdf Llew | ||
| | #17 | ||
My System: tm dh 6800+250 hdd usb,tevion hdd/dvd recorder,tevion upscaler hdmi dvd player,philips 42 plasma hd,.beheringer psudo surround thru hi fi ,.. | cheers people,,..and congrats to you Llew on your 10 yrs in forum,..you seem to be a serious sater,..good for another 10 + im sure,... | ||
