Help Required - Super Sports (Algerian) | |
| Member Join Date: 08-07-2008 Location: Norway
My System: Live in Norway. Have sky HD +. Believe it is 28.8 degrees East |
Hi, I live in Norway and currently have a SKY HD box (Sky plus) which is connected to a 90cm dish pointing at 28.8 Degrees East (I think) I have seen a Super Sports card for sale on E-Bay £159 for 12 months. I want to buy this but am unsure of the following: 1) Will it work 2) What I need in form of equipment. Firstly I believe the sighnal is on 16 degrees East. Does this mean that I need a separate dish, or can I use a new LNB with a bracket on the same dish, with the LNB pointed at 16 degrees east? I will also need a receiver and a CAM that can read Coax?? What does this really mean. In short, does anybody know if settuping up a system to enable viewing of Super sports is feasible and/or relatively simple/inexpensive? Super Sports has the Premiership games on Saturday and a good deal of Boxing. If the above does not work, what about getting ZDF and RTL from Germany? How would I get them. They also have lots of boxing that I cannot get otherwise. Hope someone can help. | ||
