Postioning LNB
Thread Tools Display Modes
Old 15-05-2004   #1
My System: Technomate 9100 and 90cm dish motorised
Exclamation Postioning LNB
Hi
I have just bought a 90cm Triax dish with a grey 0.6 MTI LNB. I am a bit of a newbie at this. There is some variation on how far the LNB should stick out from the plastic clamp. Where should it be clamped? As near to the plastic cap end as possible, in the middle or nearest the coax end??
This adjustment defines the amount that the LNB sits away from the dish so is this crucial or doesn't it matter. If it does matter where should it be?
I would try to draw what I describe but all I can come up with in text is this below. I hope you can understand it!!!!
I I----I--I--
I I LNB
I I----I--I--COAX END
CAP C
END L
M
P
Would be grateful of any help. At the moment I am just trying to align it without a motor...that comes later, when i have tried different sites in the garden!
martinw01908 is offline   Reply With Quote
Old 16-05-2004   #2
rolfw's Avatar
Moving the LNB in and out will of course change the focal distance, it is important, but it is a case of trial and error, try and see which position obtains the best result.
__________________
Rolf
Donate
Old 16-05-2004   #3
Mod and septic resident
Channel Hopper's Avatar
Hi Martin
Dont worry about experience, we all start at the bottom
Offset dishes are a bit of an odd one, where the manufacturers rarely include the specific feehorn for optimum performance, and so you are left with the fitting of an aftermarket one, or use a combined LNB with integral feed.
The LNBs available provide a 'one size fits all' type feed where the focal dimensions are designed for quantity sales rather than quality results.
Ideally the best way to install is to have an analyser on the cable when checking for best performance (which is not just signal gain, but minimum unwanted noise)
If this is not an option then its worth finding the weakest satellite signal you can receive - in the UK on a 90cm you may find Sirius channels such as Single 24/7. Using this you can adjust the feed for both focal distance and skew, to bering the best out of the outdoor components
__________________
Old 16-05-2004   #4
OK cheers guys I'll leave it loose in the middle and try adjusting it for best results later. I'll let you know how I'm getting on, great weather for it this weekend anyway.
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.3
