2K or not 2K
Thread Tools Display Modes
Old 02-04-2002   #1
w hole's Avatar
2K or not 2K
Hello All
I wonder if one of the 'boffins' could pen a couple of paragraphs explaining what 2K and 8K TV syetems are.
I came across these phrases on a site today, and don't have a clue.
Regards
W. Hole
PS. Words of no more that three sylabubs please!
w hole is offline   Reply With Quote
Old 02-04-2002   #2
rolfw's Avatar
RE: 2K or not 2K
[updated:LAST EDITED ON 02-Apr-02 AT 10:14 PM (GMT)]Here you go W H, this'll explain it better than I ever could. It basically dictates the number of jets the signal is sent out in, the 8K is the more advanced technology and allows for more jets because of the more bandwidth on the carrier.
(Coded Orthogonal Frequency Division Multiplex).
Digital transmission in a COFDM signal is low data rate QSPK or QAM modulation on carriers that are orthogonally spaced for minimum mutual interference. In 2k COFDM there are 1705 carriers and in 8k there are 6817 carriers. And MPEG-2 transport stream is fed to the transmitter where the coding and modulation take place. QSPK and QAM use both the amplitude and (I) and phase (Q) of the carrier to transmit the MPEG stream in the form of symbols. Using symbols and both the I & Q are forms of bandwidth conservation. It is important to remember that the real purpose of digital transmission is bandwidth conservation. One of the benefits is a consistent, high quality picture at all receivers above the minimum signal threshold. It is characteristic of an analogue signal to degrade gracefully, while a digital signal remains perfect until reaching the minimum threshold
http://www.digitaltv.com.au/dvbt.html
__________________
Rolf
Donate
Old 03-04-2002   #3
w hole's Avatar
RE: 2K or not 2K
Hello Rolf
Thanks for the reply, but I'm afraid that went completely over my head.
Perhaps just one more time but bearing in mind that I am pretty thick.
Regards
W.H.
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
