Missing Toecutters Den. | |
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | This should get you there Viduka. http://67.19.17.116/~toe/forum/index.php?
__________________ | |||
| Member Join Date: 22-01-2004 Location: shropshire
My System: technomate 5500,1 metre motorised dish |
hi rolfw hope you can help,i am a registered member of the den,but its not recognising me or my password now enen though i have introduced myself and donated recently regards qro1 | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | They are changing servers qro1, unfortunately they have been booted from their present one and Toe is in the process of transferral of data etc, also the new DNS needs to propogate. ![]()
| | #6 | ||
| Regular Member Join Date: 18-06-2004
| Mind if I ask how one becomes a member of either SateDudez or the Toecutters forum? Would be interested in learning about the various encryption systems/tools. Is there some sort of initiation process you have to follow? :) | ||
| | #7 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You can join Satdudez, but I believe that the membership is at present closed on Toecutter's Den.
| | #8 | ||
| Super Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | I like the idea of an initiation ceremony.... as long as I don't have to do it!!! Maybe it could include trousers, electricity and water, like in the St. Trinians movies... Is TCD having trouble with its new hosts, or is it technical? It was becoming increasingly slow over the last week or so... | ||
| | #9 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | It has been forced to move yet again over the last couple of days, the new link has been inserted in the link in Nobbly's Big Links forum, under Satellite forums.
| | #10 | ||
| Member Join Date: 31-10-2003 Location: east sussex
| Hi Rolf Thanks for sorting out my donator status on TCD with the request from Loop Guru re prittstick (me) recently. can you help with some info on TCD? Cant even register on satdudez and havnt enough posts here to send pms!! so all in all i,m stuck and in the dark !! Any help much appreciated regards prittstick (tim) | ||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | What do you need to know Tim?
| | #12 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Got to go out now, but will be back in this afternoon, you can always PM me on Toe's. You should be able to PM me here now.
| | #15 | |||
| | #16 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Oops, I tell a lie, can't get in at the moment, was on there 20 minutes or so ago, but was watching the football. Try this one http://67.43.4.157/forum/index.php?
| | #17 | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Well, it is sad Toe seems to have such a difficult time. But for all your key files and stuff there are other sites that have it on. And don't forget here is where all the fun is!!
__________________ I only believe stuff that comes straight from Mr. Horses mouthHelp build Satellites City! Help build the Satellites MiniCity - no downloads, no money involved, just a daily click onto the site. More details here: http://www.satellites.co.uk/satellite/717922-post1.html | ||
| | #18 | ||
| Member Join Date: 23-10-2003 Location: London
Any news on where Toecutter's Den is now? I'm a member and I've been away for a while, but I can't find the site anymore. Can someone please help me? I've also got problems finding SatDudez aswell. CHEERS CHAPS!!! CG | ||
| | #19 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Dudez should be where it was before http://www.satdudez-forumz.com/forum/, although the server is probably under a heavy load. As for toe's, I hope he will be getting it sorted, but If I were him, I would have a long long rest.
| | #20 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | LOL, 1,500 members online at the moment. ![]()
| | #21 | ||
My System: Dreambox 7000, Skystar2 | Yeah, it would be funny if it wasn't so sad Think you're right, sounds like the ideal opportunity for him to have a good long break. I don't know how he's had the strength to battle on this long. ![]() Don't think you can keep a good man down tho. ----------------------------------------- You can never have t many smilies.----------------------------------------- | ||
| | #22 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Certainly can't http://67.43.4.157/~toe/index.php? ![]()
| | #24 | ||
| Specialist Contributor Join Date: 14-03-2004
| Hi rolfw Managed to reach tocutters this morning I think, site I reached will not except name or password. ( have sent e mail via link @hccnwt.nl) do you know if this is correct link ?. Have not been on line for six months TV and computer was put out of bounds by a young lady who insisted on sticking needles in my face and cutting bits of it away. Still thats water under the bridge now, but as I will be missing Viasat decided to try MM and on recomendation from board will be ordering one if thay still supply them and they will work on an Echostar dbs2110 Via: @ 2 CI. Thanks in advance if you can give me any information. loftyj | ||
| | #25 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | http://67.43.4.157/index.php? Think that you're going to have to re-register, as I cannot find a loftyj in the members list there. ![]() Totally out of touch with the MM, have a look in that section or pose the question in there, may be worth looking at the Dragon or Matrix revolutions also. ![]()
