satbox dvd vcr tv connection - advice please | |
| Member Join Date: 08-06-2004
| Honestly, I've searched the site, the faq's etc, and haven't found the information I need. My question is simple, and has probably featured here before. I've just bought a new TV with a full suite of sockets on the back - you could connect dozens of things to it as far as I can see. What I need to know is how to connect my satbox (Sky Panasonic job, 2 or 3 years old, VCR and TV scarts) , fairly old vcr (1 scart), less old DVD (1 scart, s-video out) to make the system work optimally. Do I daisy-chain some of these components, (though I've been warned against feeding the DVD signal through the VCR), or should each one be directly connected to the TV? If the latter, how do I get to record from the satellite feed to the VCR? Humble request for help Thanks Richard | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Hi Richard, run the VCR into the Sky box and the Sky box into scart 1 on the TV (should have RGB enabled), then run the DVD into whichever scart on the TV with SVideo capability. This way you can record Sky and the video will take control when you play back a video.
__________________ | |||
Thanks very much for the guidance. One final (hopefully) thing. If I want the flexibility of having "standard" aerial connection as well, which component should that go into? Currently it goes into the satbox, and from there to the VCR and then to the TV(!) Is all that redundant? | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | No not redundant, but unless you are using the second output from the digibox to feed another TV, miss it out of the RF loop. ![]() So just go from the wall into the video and from the video to the TV.
Similar Threads | ||||
| System advice needed | harrisuk | Digital systems | 1 | 22-06-2005 04:30 PM |
| Connection Difficulties | j_phillips10 | Multi-receiver/TV systems | 1 | 07-01-2005 06:33 PM |
| connection sharing through aol | F1Mike | Computer Discussion | 1 | 20-10-2004 12:53 PM |
| advice needed | rob43 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 10 | 30-11-2003 01:40 PM |
| Ezdvbxl 2.5 Main feature DVD playback with some bugfixes etc | Big Ted | Satellite PC Card Systems & Internet by Satellite | 0 | 16-03-2003 02:06 PM |
