Planning permission in UK | |
| Guest
Posts: n/a
Hello I am in SW England and currently have a Sky Minidish pointing at 28.2 for Sky Digi, and a temporary ground mounted dish pointing at 19.2 for Astra 1 and Hotbird when I manually repoint the dish. I am looking at getting the dish mounted with a motor up on the roof somewhere, but need to know what the exact rules are as I dont want to shell out for a motor and installation to have it ordered down by the council. Is there a limit on only 1 dish per household, and if so what size dish can be put up without needing permission. Any advice would be great. | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. |
Right, as far as I can remember, in general terms in England (some regions may have slight amendments to this) One dish only, consent required for more (most people ignore this) Maximum size 90cm Maximum height, the top of the dish must not be higher than the highest part of the roof excluding the chimney Maximum height of dish smaller than 45cm (I think) not higher than the highest point of the building including chimney. Not sure how the rules affect garden mounted dishes. Rolf
__________________ | |||
| Guest
Posts: n/a
Hi fellas You will find that the max size dish anywhere on the premises is 90cm. Special rules apply to listed buildings and conservation areas which usually means no satellite installation at all. Some Local Authorities are stricter than others. asimov | ||
Similar Threads | ||||
| Any Help for getting round a Dish setup ? | rs_andy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 9 | 21-02-2006 06:32 PM |
| Planning Permission + two Dishes Permission | Burnham Beech | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 7 | 07-02-2005 11:25 PM |
| A planning permission for a 1.2m dish? | kirilcho | Digital systems | 5 | 15-09-2004 03:51 PM |
| Astra 2d..South Sweden, which size dish please! | Rabbit | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 89 | 15-08-2004 11:06 AM |
| Hackers planning website 'massacre' | net1 | Computer Discussion | 0 | 02-07-2003 10:30 PM |
