Re Problems With Sharp Widescreen Telly
Discuss your wife's objections to the fifth dish going up or your concern that there's far too little violence on the box these days. You can also introduce yourself here or just chat about anything. Remember, no keys or files allowed.
Old 08-10-2004   #1
I'm not sure that this is the correct forum for this but I am hoping someone can advise me.
My mum has a Sharp Widescreen TV - no satellite or freeview as yet - however she is experiencing some problems which we have always put down to reception difficulties as she lives in a block of flats.
Although the picture is fair-ish and watchable, she gets what I can only call 'scribble' across the screen. Thin purple lines zigzagging from one side to the other. We did think it might be a reception issue however having played several pre recorded videotapes and had the same thing occur with them it looks less likely. Also she runs a small portable off the same ariel with none of these problems.
Before we go mad and call out a repair man, does anyone have any suggestions as to what this problem might be. If it's a 'fatal' problem then at least we can be braced for impact.
NIKKI D is offline   Reply With Quote
Old 08-10-2004   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
Hi Nikki
Sounds like some form of parasitic oscillation in the line circuit.
Not a lot you can do yourself unfortunately, but if you can supply the model number (on the back) I can check my stock faults list, but I think this might be purely an academic exercise as you will most likely need to have it repaired.
Llew is offline   Reply With Quote
Old 08-10-2004   #3
Hi M8,
It may well be the video recorder, causing your problem try taking the video recorder away from the tv altogether. then see if you still have problems. in take away video recorder i mean completely away and not connected to any power supply. hope this helps you. wurzel.
wurzel is offline   Reply With Quote
Old 08-10-2004   #4
Mod and septic resident
Channel Hopper's Avatar
When you say 'same aerial', or are you using one of the set top aerials, or something via a wire to the socket in the wall /
Old 11-10-2004   #5
This is via a socket in the wall. She had it professionally 'piped' through so that she got good reception on the telly in the bedroom.
I thought it might be a problem requiring a repairman but I thought I would check it out first
problems, sharp, telly, widescreen
[IMG] code is Off
Similar Threads
Sky+ recording problems pjb Sky+ (Plus) and PVR Systems 4 17-06-2004 11:46 AM
Problems.... ZeeJay Magic Module 19 22-02-2004 01:27 AM
Few people seek help for sex problems net1 The Meeting Place 0 22-08-2003 08:11 PM
Problems... Help ! iwearflares Analogue systems 2 11-08-2003 08:01 AM
BBC News 24 Widescreen Fault? snoods Sky Digital (BSkyB) and Astra 28.2 East General 0 19-07-2003 12:59 PM
