Connecting it UP.
Thread Tools Display Modes
Old 07-09-2001   #1
No1 Satellite Thick Idiot
My System: Sony KLV26HG2 LCD TV, Humax HD-CI 2000 on a Fixed Sky/Astra/Hotbird. Cerebro Card. Infinity USB Phonix. Dragon Cam v4.1 w/Firecrypt & Loader Card.
Connecting it UP.
Connecting it all up.
I have the following equipment
Television with 2 scarts AV1 AV2
Video with 2 scarts AV1 (in/out) AV2 (in)
Skydigibox with 2 scarts labeled as VCR and TV
Nokia digibox 9800s (bought today!! with 2 scarts labeled as AUX and TV
Please cam you give advice on how to connect all this together with scart cables.
I am very confused on which scart end goes where. I would like to able able to record any of the devices.
I would want to watch the device I switch on through the AV channels on my tv. If not possible I don't mind have VCR as RHF connection.
Please give me a easy to understand guide on how to connect this lot.
Many thanks in advance.
Shahid
Shahid is offline   Reply With Quote
Old 07-09-2001   #2
rolfw's Avatar
RE: Connecting it UP.
OK Shahid, this should work.
VCR scart 1 in/out to digibox VCR socket
DigiboxTV socket to TV AV1
VCR AV2 in only to Nokia AUX
Nokia TV to AV2 on TV.
You may have to reverse the two TV connections if you have problems.
Rolf
__________________
Rolf
Donate
Old 07-09-2001   #3
Post RE: Connecting it UP.
So I take you have based it with no RHF for the video needed. As there is no direct scart from video to tv AV1 or AV2 .
So does the signal for the video being played go through the skydigibox as it will be on standby?
Will this setup let be record from the whatever digital box (SKY/NOKIA) is on?
Old 07-09-2001   #4
rolfw's Avatar
[updated:LAST EDITED ON 07-Sep-01 AT 09:45 PM (GMT)]That's correct Shahid, the digibox should allow play through by the video even when it is in standby.
The only further consideration is then the terrestrial aerial lead and that shoul run through the video to the TV, there is no need to pass it through either digital receiver.
To record from either receiver you will have to set the video to either AV1 or AV2 by using the channel down button.
Rolf
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
Similar Threads
Sky digital connecting new box to minidish and test chanells? N00b Digital systems 8 18-06-2005 12:31 PM
Connecting the receiver to the pc (Cable) FeBonti Viaccess 11 31-05-2005 10:37 PM
Getting message "can't resolve host name" when connecting DB by ethernet Tore567 Dreambox General 4 28-02-2005 08:36 PM
Connecting with dreambox dobblek Dreambox General 6 19-08-2004 01:19 AM
connecting argoran Multi-receiver/TV systems 2 10-06-2001 01:03 AM
