Removal of Double sided tape from Plaster Wall
Discuss your wife's objections to the fifth dish going up or your concern that there's far too little violence on the box these days. You can also introduce yourself here or just chat about anything. Remember, no keys or files allowed.
Old 07-12-2005   #1
Mod and septic resident
Channel Hopper's Avatar
This stuff is usually seen in auto shops and used for sticking number plates onto the car.
Im looking at an internal plaster wall where the last owner has stuck posters up using this stuff
How do I remove it as its not coming off in any great hurry with a putty trowel. Any more force and I will damage the gyprock surface.
Is there a solvent on the market that can shift it ?
HELP.....
Old 07-12-2005   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
A solvent of some kind usually works on that stuff (paint thinners etc.)
May leave a sticky residue, just reapply again. At least it worked on brickwork, although it left a slight stain. Don't know about more absorbent surfaces (plaster).
Llew is offline   Reply With Quote
Old 07-12-2005   #3
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
is this any good
www.ehow.com/how_18750_remove-double-sided.html
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 08-12-2005   #4
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
The type of thinners you need is not cellulose (car paint) thinners.
What you probably need is stuff that is normaly sold as degreasing fluid in te car refinish trade i.e. it doesn't react with the paint. I have used it to soften the adhesive when taking number plates and trimpanels off cars. It isn't very fast though, you have put it on , leave it a while and then ease the sticky pads off with a plastic blade.
Have fun...
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 08-12-2005   #5
I was going to try a can of WD40 and leave for the weekend , but as you say , degreasing, I would probably be better off with spray on gunk or something.
Not sure how the plaster wall will like it ...
Old 08-12-2005   #6
rolfw's Avatar
Real name: Rolf
Try some plain and simple alchohol first.
Rolf
Old 08-12-2005   #7
Llew's Avatar
Yes, after you've necked that back, you're ready to tackle the job
Old 08-12-2005   #8
BGonaSTICK's Avatar
LOL, a hammer, chisel and some polyfilla would probably be quicker...
Old 08-12-2005   #9
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
You could try softening it with hair dryer/fan heater
pgh13 is offline   Reply With Quote
Old 09-12-2005   #10
Fraid not. Someone has used a whole reel of the stuff to stick posters up.
I estimate 3 square metres is attached to the wall in horizontal strips with a gap between each of 2cms.
Its a real mess , and this stuff just ignores the scraper tools.
Old 09-12-2005   #11
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
Have you tried white spirit after warming it with a hair dryer? If you use WD40 you won't be able to paint the wall again as it's oil!
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 09-12-2005   #12
I'd be inclined to try lighter fluid - it dissolves most 'sticky label' type glue. It might require a second application with a clean cloth afterwards, its a good degreaser too.
bobed is offline   Reply With Quote
Old 09-12-2005   #13
My System: 60cm dish, dual LNB, Topfield TF5010PVR
Acetone will do it, though with that area quite a lot. If you wish to try first use some nail varnish removers (all chaps should have some in their drawer). If it works go to a local fibre glass businees, take an air tight glass bottle and sweet talk them into letting you have some, that's the cheapest way I know of obtaining it.
John T is offline   Reply With Quote
Old 09-12-2005   #14
You can get scrapers which are just a plastic handle that holds a Stanley knife blade at a very shallow angle to the surface. They are often used for gettting paint off glass, but are v sharp and may help here
Old 09-12-2005   #15
BGonaSTICK's Avatar
Acetone, or that citric solvent they use to remove coolant paste from CPU cores/heatsinks would be my first try. Pure medical alcohol is probably cheaper. And it tastes better.
Old 16-12-2005   #16
RedDevil_UK's Avatar
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick.
A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive
put the posters back up
"A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
RedDevil_UK is offline   Reply With Quote
Old 19-12-2005   #17
The Local Drunkard
AlexBellisBrown's Avatar
My System: 130cm dish 80cm motorised dish Silvercrest SL65 FTA Internet cafe broadband Lots of FTA channels on most satellites aimed at europe and middle east.
Petrol and a match should shift it.. and the wall too...
AlexBellisBrown is offline   Reply With Quote
double, plaster, removal, sided, tape, wall
[IMG] code is Off
Similar Threads
Removal of Zenosearch Assistant from memory thewarrior Computer Discussion 4 27-10-2005 01:00 AM
Two digiboxes with one single LNB or frequent removal of viewing card? Helmut05 Multi-receiver/TV systems - Domestic only 9 23-05-2005 11:07 PM
where can i get a decent pole bracket for a wall corner or front wall! ninjagordy DISH SETUP: Single sat, Multi-Sat & Motorised systems 10 31-01-2005 03:22 PM
Bikini Model Sues Playboy Over 'Lesbian Porn' Tape net1 The Meeting Place 0 02-06-2003 10:53 PM
Free anti Pop-up and Ad removal program rolfw Computer Discussion 0 25-02-2003 06:33 PM
