Is there a FTE Maximal DIMO 120+ dealer in the UK?
Thread Tools Display Modes
Old 25-01-2006   #1
Rav
Rav's Avatar
My System: Fibo 90cm Dish, Inverto White Tech IDLP-SFLANGE 0.3dB LNB, Moteck SG-2100A Motor, Dreambox DM7020S Receiver and Sky+
I'm having trouble finding one for this DiSEqC motor, does anyone know of one?
Best price on Ebay is about £60 including delivery and bank transfer fee from sr-tronic.de
Rav is offline   Reply With Quote
Old 25-01-2006   #2
rolfw's Avatar
Well it looks pretty much identical to the Moteck SG-2100, so you may find one of those more readily.
__________________
Rolf
Donate
Old 25-01-2006   #3
Rav
Rav's Avatar
Not quite the same. The FTE has a 55mm tube diameter and its maximum dish weight is 27kg, which should mean it's significantly more robust than the bog standard Motec.
I guess it's Ebay then!
Old 25-01-2006   #4
rolfw's Avatar
There are three types of Moteck, one with a 50mm tube one with 52mm and one with 57mm and all of them carry the same dish size recommendations, it isn't the diameter of the tube which is critical, it is what is driving it and how it is attached.
PS. Just looked at the spec foe the older Moteck SG-2100, that one has a 55mm tube, so it will possibly be a clone of the old one http://www.satellites.co.uk/php-bin/...5&d=1112208919
__________________
Rolf
Donate
Old 26-01-2006   #5
Rav
Rav's Avatar
Thanks for the good information.
Will be going with the newer Moteck then. Read in another thread that the quality of the U-bolts is poor and they may need to be changed, but I'm prepared for that.
Old 26-01-2006   #6
rolfw's Avatar
Yes they (the U bolts) are not the best, but from experience they are OK if not over tightened, also a little vaseline or grease on them will possibly avoid any future problems.
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
Similar Threads
Fte Maximal Pasor Cams and decoders General 0 09-04-2004 04:28 PM
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.3
