If U ever need some horsepower | |
| Prince of Birthdays Join Date: 28-09-2005 Location: Sweden
My System: Dream7020 and lots of junk all over the place |
The engine is a General Electric Model T58-8F. This is a helicopter turboshaft engine that was converted to a jet by some internal modifications and a custom tailpipe. The engine spins up to 26,000 RPM (idle is 13,000 RPM), draws air at 11,000 CFM, and is rated at 1350 hp. It weighs only 300 lbm. It grows as it warms up so the engine mounts have to account for this. The mounts in the front are rubber and the back are sliding mounts on rubber. The structure holding the engine was designed using finite element analysis and is redundant. Strong, damage tolerant, and light. Sec ond battery and fuse/relay panel on the right, halon fire system and 5 gallon dry sump tank on left. 24V starter motor is in the nose of the engine. 700 A of current goes into that motor for 20 seconds during start-up. Due to heat, must limit starts to three in one hour. Big screen is to avoid FOD (foreign object damage). Jet keeps sucking the rose out of the bud vase on the dash! | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Crumbs, you wouldn't want to be sat too close behind them at the traffic lights.
__________________ | |||
| Super Moderator Join Date: 24-09-2004 Location: Rochdale
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | thats just what i was thinking rolf lol is that just for showing off and decoration... or does it actually make the car faster? and why a VW Beatle lol
__________________ "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." | ||
| | #5 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
Surely you would have to drive with the windows open otherwise the driver would pass out from oxygen starvation or get sucked into the intake and end up as pate flambe
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
