Every satellite hobbyist should have one. | |
| Guest
Posts: n/a
cheap multi meter http://www.maplin.co.uk/Module.aspx?...eria=CLEARANCE | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Moved this into the general section Rd100, as everyone should have one and this is a really good deal.
__________________ | |||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | multimeter for what ? lol must be missing something obvious | ||
| | #5 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
It is called a Bargain
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Well I've found mine invaluable, you can check the voltage output of your satellite receiver, the voltage at the LNB, the fuse in the plug you've fitted, whether the fused spur you are wiring into is disconnected, whether the coax is shorting out, whether there is voltage to the TVlink. I wouldn't be without mine, has saved me hours and hours over the years and any satellite or aerial installer who hasn't got one must like wasting time. ![]() This particular one is so cheap that anyone can afford it and is of use at home, even if you don't play around with satellites.
| | #7 | ||
| Regular Member Join Date: 19-12-2005 Location: Derbyshire, England
My System: comag sl65 (x3) Sad but I like them :-) comag porty II (camping) Pace Prima (analogue) Assortment of dishes. computer: Shiney new Acer |
They did a similar deal a couple of years ago in the stores. Electronic multimeters - 2 for a fiver. At that price I had to have them. Swapped one of them with a mate for a couple of beers They're both still going strong and in regular use.
__________________ The caravans are coming. Happy Traveller. | ||
| | #8 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | i already have one for measuring 12v, 5v output on pc power supply when i'm overclocking pc but honestly didn't know about using them for sat stuff | ||
| | #9 | ||
| Oldgeezer Join Date: 04-09-2004 Location: West Mids, UK
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | Something I use a lot, and I have several expensive one's about that I can never find when required , but for that money I think I shall get a couple, if they've any left, they want nearly as much for a spare battery. At least it should increase my chances of finding one
__________________ Oldgeezer | ||
| | #10 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Wouldn't be without my AVO 8. A magnificent beast - analogue of course, useful for checking capacitor discharge time. Llew | ||
| | #11 | |||
__________________ Oldgeezer | |||
| | #12 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | I wouldn't let it out of the house - got cheapo digis for that | ||
| | #13 | |||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| It was a pretty good poormans solution back then to adjust your dish. | |||
| | #14 | ||
| | #15 | ||
| Specialist Contributor Join Date: 05-04-2005 Location: Midlands UK
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP | | ||
| | #16 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | These young'uns think they know it all Old Geezer. When we get shuffled off to the retirement castle, we can talk about how we had to make our own diodes from bits of coal and fuse wire (true) Llew | ||
| | #17 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | LOL, another use - that recessed dial was handy for holding tiny screws etc. | ||
| | #18 | ||
| | #19 | ||
| Member Join Date: 19-02-2004 Location: Co.Kerry Long 9.90 W Lat 52.11 N
My System: Shuttle PC 2.8ghz Sky Star 2 80cm Dish and Moteck SG2100 | | ||
| | #20 | ||
| Regular Member Join Date: 01-01-2000 Location: Aberdeen, Scotland
My System: Channel Master 1.2m motorised, V Box, Technomate 1500ci. | You've just reminded me that I have an AVO 8 - I may get it out of the cupboard tonight where it is stored in its magnificent leather case, just to have a look at it. I very rarely use it nowadays. The Maplin multimeter looks the biz for under £3 - last thing I need though!
__________________ ![]() Satellites.co.uk F1 SupaLiga 2008 - 2nd Satellites.co.uk PL SupaLiga 2007/08 - 2nd | ||
| | #21 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Ah, the leather case! Smelt like the inside of a prestige car I see the latest AVO 8 costs close to £600 now... A friend gave me mine ages ago, couldn't have afforded a new one. Did buy an Avo 8 Panclimatic (NATO job) before that from Henry's in Tottenham Court Road - a wonderland of army surplus gear - but it developed a stuck movement. Llew | ||
| | #22 | ||
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide | That brings back some happy memories, one of the few good points of going to London. There used to be a few interesting shops in Totenham Court Road
| | #23 | |||
| But after EU and all that fancy crap all countries were all the same and had the same stuff wherever you visited. Kinda boring these days visiting another european country these days as they are all the same. | |||
| | #24 | ||
Mine arrived today and very nice it is too, much better than the 15 year old one I have which is well past its sell buy date, damaged leads, probes fallen off many times etc cheers Rd100
| | #25 | ||
| Post Meister Join Date: 31-12-1999 Location: Berlin, Germany.
My System: 2xPace 430N, 1xNokia MM9800, 1xNokia 80cm Sat Dish, 1xGibertini 120cm, Big Fat Furry Puss | When I saw that AVO thumb I smilied. In fact, I was reminded of the same thing the other day on a TV programme (AVO = Amps Volts [and for the younger ones] have a guess what the means, LOL.Like many others here, I too used [suffered] this gem when ascending the elctronics ladder. Have long since descended the same ladder, hehehe. First thing I did when I left college was to buy an electronic Multimeter (from Maplins) - still use it :-)) Doesn't do capacitor discharge readings very well - but comes in handy when I have to re-install Photoshop. Moo. .
__________________ Have Fun, Moo. | ||
