Build Quality | |
| Super Moderator Join Date: 24-09-2004 Location: Rochdale
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive |
is it just me that finds it slightly suspicious that sky boxes always blow or break down after 18 months? in my time with sky, ive now had 8 receivers (and i need another now!!) the dreambox goes on year after year.... and never even makes a funny noise or anything. is our Rupert asking for his boxes to have a life expectancy of his contracts? or am i an angry paronoid receiver breaker
__________________ "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II 1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs ![]() Saved us from the black plague of ignoratio elenchi, he awaits a special badge with jugs | The boxes, can only react to the OTA updates Sky send to them, if some of the programming is causing them to fail then that is down to sky or sub contractor of. I have to confess that listening to people at work where a large number of them have sky, it seems odd the large number of stories corroborating the notion that whenever that insurance phonecall comes to say the warranty is running out on such and such a day and if you do not renew you risk etc etc then after not renewing three weeks later the box dies, is really quite alarming. I can see no technical reason for that not to be possible but would they really dare....mmmmmm I think we all know the answer on that one
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | This has been mentioned in another thread, but I'm pretty sure that no company of that size would risk doing that, it would also be very time consuming, as they would have to have two different software versions for insured and non-insured. Bearing in mind that there are now something in the region of 8 million subscribers, there are bound to be a large number of people who's boxes fail, particularly if they have Amstrads. ![]() I have had one sky+ box break, otherwise all the others I've had have been fine, my very first box, an Amstrad, finally finished life the Christmas before last over at my sister's place, but had a damned good run.
__________________ | |||
Perhaps they have made the mistake of allowing the MTTF of the componants to be the same of length of time as the insurance policy then ![]()
| | #5 | ||
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: Dbox + Skystar2, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | Reminds me of the old "what's that timer IC doing in a burglar alarm system" (an old scam where the burglar alarm system stopped working after a pre-defined time). | ||
| | #6 | |||
__________________ "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." | |||
