3g unlock code? | |
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Have a look here http://www.mobileexpert.co.uk/mobile...ad.php?t=17166
__________________ | |||
| Member Join Date: 08-07-2005 Location: south
My System: Fortec Star 5100 CI Diamond 90cm ISS Dish 0.3 Fortec Star LNB @SAT Disq 1.2 Motor | try here: http://www.fonefunshop.co.uk/Unlocki...moteunlock.htm Got my NEC 3G unlocked using an unlocking kit cost £25 included moddified cable software disc etc, unlocked quickly and dispatched by them promply, i understand that your phone can be unlocked online and costs about £15 hope this helps, MMS doesnt work, and the internet can be used by clicking the triangle button wait for it to start connecting then click cancel you may then type in your URL address you wish to access not all sites work but PDA sites are compatible and game sites also. Ive got a vodaphone sim in mine and it connects to 2.5G my mates got the same phone with an orange sim in it and that connects to 2G. Most modern sims are all 3G compatible definately with vodaphone so there shouldnt be any problem putting it in the phone, T-Mobile are a pain cause they use an odd voltage so they arent so reliable but then your not missing much there! | ||
| | #5 | ||
| Member Join Date: 22-06-2006 Location: pakistan
My System: ??? | hahaha if your c975 version is lower than 6.12 so you can unlock it easily with Smartclip by only press the unlock button no need to attach with PC,and if its higher than 6.12 so you need to remove RSA and after remove RSA phone will come auto lower version so you can unlock it manually by press unlock button for more details visit www.smart-clip.com BR Kashif Khan | ||
| | #6 | |||
| Member Join Date: 06-07-2006 Location: KINGDOM OF SAUDI ARABIA
My System: Satellite Channel Unlock key |
Similar Threads | ||||
| the function of the master code (secret code) of receivers | tatawinw | Receiver software, international Section | 3 | 10-08-2008 08:25 AM |
| how to unlock more channels ? | nebon | Dreambox General | 2 | 25-10-2005 12:14 PM |
| unlock code | keith18955 | Digital systems | 3 | 10-10-2005 07:31 AM |
| Unlock | norbert G | Receiver software, international Section | 1 | 08-07-2005 08:22 PM |
| unlock ALL CHANNELS | ALiO | Receiver software, international Section | 6 | 05-12-2004 02:20 PM |
