Nokia 6100 unlock problem
Thread Tools Display Modes
Old 16-10-2003   #1
Unhappy Nokia 6100 unlock problem
I obtained the unlock code for the Nokia 6100 using the DCT4 calculator.
Also crossed checked the code from another source. Initially I was getting 'code error' and then after several attempts another error.
I can still use the mobile with my network providors simcard but as I travel a lot I want to use pay as you go sims in other countries.
The second error message states:
'Cannot undo restriction'
Any ideas?
One guy in the UK at weekend reckoned the phone is only useful for spare parts now but when I put my network sim in and it worked it seemed to blow his theory away.
Cheers,
Gary
Gary is offline   Reply With Quote
Old 09-03-2004   #2
haga's Avatar
I have a 6100 and unlocked it easily using dct 4, did you use the last code (7), try this site for help, it has got to be the best help forum for mobiles around.
haga
http://forum.gsmhosting.com/vbb.index.php
haga is offline   Reply With Quote
Old 11-03-2004   #3
hi m8 if it says 'Cannot undo restriction' code has been entered to many times youll have to do it via pc
packer is offline   Reply With Quote
Old 23-06-2006   #4
My System: ???
after 5 times wrong entry of the codes your counter has been blocked, now your cell can unlock directly,nothing else.
BR
Kashif Khan
Kashif Khan is offline   Reply With Quote
Forum Jump
Similar Threads
nokia problems!!!!!!!!!! spowpeen DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 04-04-2006 06:09 PM
Nokia motorised system RDB Digital systems 0 13-11-2003 09:19 PM
is this a diseqc problem doggy DISH SETUP: Single sat, Multi-Sat & Motorised systems 14 05-09-2003 02:44 AM
