Hi there
Each LNB on the dish has one cable coming out of it. 1st one is 19.2 Astra. The 2nd LNB is Hotbird 13.E
I don't really require the astra so can i move the Astra LNB to get Hotbird?
All I have plugged in to the original satellite (Manhattan) is the new Hotbird cable. The other cable is loose and not attached to anythilng.
The new satellite will be connected to the hotbird cable and the older box put in a different room so 2 different channels can be watched in seperate rooms.
This is a lot more confusing than i first thought. I'm just looking for the simplest way of adding a 2nd receiver.
It is 2 separate LNB's not a monoblock
can I not physically move the astra LNB to the hotbird position ? or do I need to replace the Hotbird LNB with the dual LNB?
I'm not really fussed about the astra channels. (The LNB and cable have not been used for over 3years)
Any advice / help would be appreciated
