Using Quad LNB with three receivers?
Old 12-09-2008   #1
mick2me's Avatar
My System: 'Fortec Star Passion' (& a dead SL65) One of them big Woks on the outside, and a thingy that moves it about a bit.
Any tips for this type of setup would be appreciated?
The best way to learn is from your mistakes... Sorry I made a mistake!... The best way to learn is from others mistakes.
_www.Nottstalgia.com
The Nottingham Forums
mick2me is offline   Reply With Quote
Old 12-09-2008   #2
satelliteman's Avatar
Real name: Paul
What would you like to know?
satelliteman.
An Installers Choice
Follow us on
Old 12-09-2008   #3
mick2me's Avatar
Do you need to feed each LNB with power?
The main receiver will drive the dish motor.
If no to above, is it better to power the LNBs from the receiver not driving the motor.
Also is it possible to drive the dish with more than one receiver?
Old 12-09-2008   #4
Real name: Paul
A Quad LNb will have 4 separate outputs requiring a supply feed from the receivers. If DiSEqC motor is being used, connect one to the motor and the other three outputs direct to other receivers. All feeds will be receiving the same satellites as the dish moves.
satelliteman.
Follow us on
Old 12-09-2008   #5
Robbo's Avatar
Real name: Mark
Only one receiver will be able to power the motor. The Quad LNB will derive its power from each receiver that is connected.
Old 13-09-2008   #6
mick2me's Avatar
Is there any reduction in signal level due to the fact there are four outputs
Old 13-09-2008   #7
Real name: Paul
Think of it as 4 LNb's in one housing
SM
satelliteman.
Follow us on
lnb, quad, receivers
