Originally Posted by viccos hi guys, i need some info about the Humax foxstar HDR, Can i connect 2 sat. (astra2 + hispasat ) on the humax HDR ? I was thinking this way; 2 cables from astra dish, and on 1 of those cables i could fit a diseq switch so i can connect the cable from the hispasat dish.so will be 1 cable direct to the unit and the other 2 via a diseq switch, is it possible ? will this set up work ?
Another question; freesat receivers, they are normal receivers aren't they? i can set it up on any satellite or not ?
thanks for your help guys. |
Surely you mean Humax
Foxsat HDR?
It has 2 tuners so your suggestion should work, provided it has support for Diseq.
Haven't seen it in the specification, so focus on this point first before buying it.
