How is it best to install sky in diffrent rooms of the house? | |
| Member Join Date: 02-02-2009 Location: United Kingdom
My System: Not sure what to put but just a normal sky dish with 1 sky box. |
Hi, new to the site and was hoping I could get some technical info on installing sky in my house. Currently I have just one box in the front room. I would like to have sky in at least 3 other rooms with its own individual box. Is it possible to cut into the cable from the dish to my current box and incorporate a spliter or amplifier then send the signal to the other rooms where i can connect a box on each? Also what cables do I need to run so we can have sky+, hd and any other devices we're likely to have in the future. Now's a good time as we are redecorating. Any help or advice would be greatly appreciated. Cheers | ||
| Guest
Posts: n/a
| No you can't cut into cables or use splitters as each serviced Box needs to send switching commands to the LNB. So, you need an LNB with sufficient outputs to feed all your Boxes. One feed per Tuner, so eg a Sky+ Box requires 2 feeds. LNBs are available in single, quad and octo output. If you need more, the approach is different: You would need a Quattro LNB and a Multiswitch. PS: Just noticed you are in the USA .............. No Sky via Satellite there! Am I missing something? Actually, it says US, so USA is a guess: I suppose you could mean the United States of Europe ? | ||
My System: Not sure what to put but just a normal sky dish with 1 sky box. | Cheers for the information, i didn't actually have a clue that was what needs to be done, so thats a great help. Must of filled out the form to quick because i am in the UK | ||
| Guest
Posts: n/a
| | #5 | ||
| Regular Member Join Date: 21-04-2007 Location: nottingham
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized | Actually, it says US, so USA is a guess: I suppose you could mean the United States of Europe ? could stand for upper sandusky | ||
| | #7 | ||
| Member Join Date: 01-02-2009 Location: Dinas Powys
My System: Sky Dish Single LNB Sky receiver Digital High Gain Aerial | Hi Jimek I joined yesterday Im trying to do the same as you to include digital aerial feed as well to each room - had real good advice from members I have uploaded some diagrams hope I can say this here. Good luck with install xx | ||
| The Following User Says Thank You to xxulovethenewbiesxx For This Useful Post: | jimek (09-02-2009) |
| diffrent, house, install, rooms, sky |
