magic eye problem when i plug scart lead
Old 11-03-2009   #1
My System: 1m motorized dish
hi all needs some help
my magic eye stops working if i plug the scart lead into the sky box to tv
does that mean my box is faulty or just i cant use magic eye when scart is pluged in.
parm21 is offline   Reply With Quote
Old 13-03-2009   #2
aba
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized
have you tried pluging it in to the other scart socket on the box and then the tv
or even try another scart lead
aba is offline   Reply With Quote
Old 13-03-2009   #3
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Just to confirm...
Your Digibox is in one room normally connected to the main TV by the TV aerial lead and the magic eye is in another room where the 2nd output from the Digibox goes through the eye before going into the second TV. When you add a scart lead to the Digibox to connect it to the main TV the eye in the second room stops relaying channel changing information back to the Digibox?
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 14-03-2009   #4
yeah thats right
Old 14-03-2009   #5
PaulR's Avatar
The magic eye should keep working regardless of what method you use to connect the main TV to the Digibox. It's important to always use the second aerial output of the Digibox for the second TV as the magic eye won't work on the first aerial output.
I can only think that Digibox is faulty, perhaps something wrong with the internal power supply that is just at the limit of its capabilities. Just guessing about this really. Is there another Digibox you could borrow that is working with a remote eye elsewhere?
The Following User Says Thank You to PaulR For This Useful Post:
parm21 (16-03-2009)
eye, lead, magic, plug, problem, scart
