In satellite signal distribution is impossible to have all the transponders at the cable simultaneously.
In goffy's setup the cable can either have the transponders of:
Sat1, Vertical, Low band
or
Sat1, Vertical, High band
or
Sat1, Horizontal, Low band,
or
Sat1, Horizontal, High band
or
Sat2, Vertical, Low band
or
Sat2, Vertical, High band
or
Sat2, Horizontal, Low band,
or
Sat2, Horizontal, High band
If the first receiver is tuned (for example) to a transponder at Sat1, Vertical, Low band then the second receiver can only receive from Sat1, Vertical, Low band.
In order to have a second receiver you should replace the LNBs with dual ones, buy a second DiSEqC switch and install a second cable. |
