Using Triax TMS 17x8C Multiswitch instead of DiSEqC Switch
Old 28-03-2009   #1
al_madhi's Avatar
Question Using Triax TMS 17x8C Multiswitch instead of DiSEqC Switch
Hi , ppl I would like use Triax TMS 17x8C Multiswich instead of DiSEqC Switch . Now I am connecting four satellites using ordinary way using a DiSeqC switch with four inputs , input # 1 connected to Hotbird , input #2
connected to Nilesat , input #3 connected to Arabsat and input #4 connected to Asiasat3S . So when programming the satellite receiver I configured Input # 1 to Hotbird , Input #2 to Nilesat , Input #3 to Arabsat and Input#4 to Asiasat3S , according to the DiSEqC switch .
But Using Triax TMS Switch the LNB will be changed to a Quattro LNB which has four inputs ( High , Low , Vertical , Horizontal ) for each satellite . Therefore my question to you when programming the satellite receiver how I am going to configure the four satellites connections , because there are no such thing in the satelite receiver says High , Low , Vertical and horizontal according to the Triax TMS switch .
Any thoughts you would have be greatly appreaciated .
Best Regards .
A.M.AL-MADHI
AL-MADHI
al_madhi is offline   Reply With Quote
Old 28-03-2009   #2
satelliteman's Avatar
Real name: Paul
Install a quattro LNb to the switch for each satellite. DiSEqC 1.0/1.1 commands from the receiver will select between the satellites. Note, the switch defaults to quattro input 1 without any commands.
satelliteman.
An Installers Choice
Follow us on
Old 28-03-2009   #3
al_madhi's Avatar
Question
Thanks satelliteman for reply
" DiSEqC 1.0/1.1 commands from the receiver will select between the satellites. "
From your statement above You are mentioning a DiSEqC 1.0/1.1 switch ,
But there is no access for connecting a DiSEqC switch in the Triax TMS Mulitswich Could you please elaborate more how to connect both switches the DiSEqC switch and the Triax switch to the receiver
AL-MADHI
Old 28-03-2009   #4
Real name: Paul
Forget about the DiSEqC switches.
Hard wire 4 x quattro LNb's to multiswitch inputs.
The receiver should have a 'DiSEqC 1.0/1.1' installation menu, set up for each satellite, 1,2,3,4 or a,b,c,d to allow switching between the sats. By default, feeds from LNb input 1 will be received with out setting up any DiSEqC switching on the receiver
satelliteman.
Follow us on
Old 12-04-2009   #5
My System: HDCI-2000 Spaun 9 input multiswitch Dell Optiplex OS: XP pro
PS: DiSEqC 1.0 is needed in this application. Reference to DiSEqC 1.1
is unnecessary & may confuse.
eg: I have yet to find a Humax model (including iCord & HDCI-5000)
with DiSEqC 1.1 which is a pity. Topfield all have 1.0 & 1.1.
In this case a switch like the Spaun SUR 211F can be used to add
a 5th orbital position seamlessly if receiver has v1.1
HiBand is offline   Reply With Quote
17x8c, diseqc, multiswitch, switch, tms, triax
