No Signal on second receiver!
Old 06-04-2009   #1
My System: sky hd+ Two lap tops connected via adsl
I have sky hd+, I have the old sky+ receiver that I wanted to connect in our kitchen so that we could watch free view via the old box. I have connected a third coax lead from the lnb to a female to female "f" barrel (6m) and then to the kitchen (40m). When I connected the lead to the receiver in the kitchen, I am unable to get a signal.
I then connected the old sky+ receiver to the 1st part of my new extension, so from the lnb to the old receiver about 6m - this worked ok. The 2nd part of my extension, the 40m coax lead to the kitchen was already in use via the RF out 1, the picture was never a very good quality this way either.
Can I get advice? do I need to run a new coax cable at a better quality or will an amp do the job?
An ideas?
quirko is offline   Reply With Quote
Old 06-04-2009   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum quirko
Well I assume you had a quad output lnb to begin with then, if you are using the original rf out cable that was part of the internal house wiring, it will be the wrong cable and will more than likely be attenuating the signal, I am not clear what the short 6mtr length is doing, just take a lead from the lnb to the original sky+ unit in the kitchen.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
The Following User Says Thank You to Topper For This Useful Post:
quirko (07-04-2009)
Old 06-04-2009   #3
Mod and septic resident
Channel Hopper's Avatar
Stick the second box in the kitchen with a cable direct from the dish , if it works, leave it well alone
The Following User Says Thank You to Channel Hopper For This Useful Post:
quirko (07-04-2009)
Old 07-04-2009   #4
I'll have to run a new coax cable direct from the dish. Thanks for your help.
Old 07-04-2009   #5
Topper's Avatar
Well
Originally Posted by quirko View Post
Just make sure you use satellite quality cable
Show Your Support
Thank you.
receiver, signal
