The setup is a little difficult. All the cables for the dish and the aerial arrive in a cupboard, where the satellite box and digital tv signal booster are housed. From there another 2 cables run from the signal booster through the walls to two televisions. I am not bothered about having satellite on both tvs, just one would do. The connections on the back of the satellite box are as follows:
Spdif; coaxial and optical, video, svideo, serial port, tv scart, vcr scart, lnb in and if out, along with audio connections.
Yours, uscwap |
