2 satellites to one humax HD box
Old 14-05-2009   #1
Real name: terry
My System: humax freesat hd receiver with old sky dish
Hi
I know that I can get non-freesat channels on my Humax box, which I currently use on the freesat satellite (28.2E). If I use a double LNB (with single output) to pick up another satellite, will the humax box be able to detect the two input signals? If I use separate LNBs with an auto switch will it detect them?
I am hoping to pick up the french tnt channels which are on 19E
I have seen references to Diseqc but have no knowledge of this
terryr1 is offline   Reply With Quote
Old 14-05-2009   #2
satelliteman's Avatar
Real name: Paul
The Humax Foxsat does have DiSEqC control and can be used with a DiSEqC switch to switch between two LNb's for two sats using a single downlead.
In this case a
possibly your referring to a monobloc LNb; for the two satellites you require, either a separate dish or a 60cm minimum with 2 x LNb's and multi-lnb bracket would be required
satelliteman.
An Installers Choice
Follow us on
The Following User Says Thank You to satelliteman For This Useful Post:
terryr1 (15-05-2009)
box, humax, satellites
