Sat TV distribution 3 rooms
Old 07-06-2009   #1
My System: echostar 3000
Hi guys
Hope you can help and advise what I need to get for distribution.
Basically I have a static caravan that I want to set up a sky reciever in the lounge area and distribute it down to two end bedrooms. Nothing fancy like multiroom just the ability to watch sky fed from the receiver in the lounge to the bedrooms and be able to change channel from bedroom. I understand all tvs will see same channel but this is not a problem as only one TV will be watched at a time.
Hope this makes sense.
Wild Thing is offline   Reply With Quote
Old 07-06-2009   #2
satelliteman's Avatar
Real name: Paul
Hi and welcome,
A simple 2 way IR distribution amplifier fed from the RF2 port of the digibox.
_http://www.globalinvacom.com/products/f140.php
satelliteman.
An Installers Choice
Follow us on
Old 07-06-2009   #3
My System: tm 9100 tm 1500 ci dm box 600 1 m dish polar mount 12 inc acuator v box 2 cas 3 dragon diablo gamma
you will need a small amp 1 input 2 output with digital bypass built in for magic eyes .. this will be fed from the rf 2output of reciever , the 2 outputs will feed other tvs for which will go into the outputs of the amp ... after that its just a job of tuning in tvs and fitting magic eyes lol ...also make sure the line voltage is turned on in the sky menus ...services .. system setup ...0 1 select ..4 rf outlets then turn on the setting to on for line power and save settings good luck ..
leez is offline   Reply With Quote
Old 07-06-2009   #4
Thanks guys. Had a look at the F120 which is 1 input x 2 output which is what I need. Just one more quick question. The F120 has F connectors. is it OK for the patch leads to run f connectors at one end and standard aerial plugs at the other end for the tv signal in.
Old 07-06-2009   #5
firstly soz satellite man , you beat me to it m8 lol ... and yes it ok to have f connectors and rf connectors lol .. it will not make any difference .. depending if you want to use tv link , you can get some that have f connectors on input of tv link ..it all depends what you buy . whether it rf or f dosen t really matter ..
Old 07-06-2009   #6
Real name: Paul
No problem at all
There are a range of amplifiers available with IR pass either mains or line powered.
satelliteman.
Follow us on
Old 07-06-2009   #7
Thank you both very much for your prompt replies
distribution, rooms, sat
