Hey all,
First thread,
A Multi-receiver setup is the plan but I don't quite know if I heading the right way with this.
Background,
3 storey terraced house , from the top; 2 rooms loft, 2 rooms mid, 2 rooms bottom.
Rear chimney stack appears to have a clear view of 28 east and west for dvb-t with the added bonus you can't see it from the road.
Property is rented so unless the landlord see's value in what's intended my hands are tied
Current setup is a old bskyb mini dish (single LNB, digi) on the face of the house and a UHF facing NE. The UHF feeds a small splitter/amp hidden under a floorboard with cables fed to most of the rooms and no wallplates :/ (why why why they are cheap). All well past the sell by date and needing to be replaced.
The goal,
DVB-T, DAB, DVB-S/2 (28.2E astra2 and 28.5E EB1) to every room with the 2 downstairs rooms getting 2 sat feeds for pvr's. 2x Cat5e to every room.
So the plan thus far,
Rooms,
triax faceplates, quad with return and bt along with 2x cat5e for the two downstairs rooms. Euro modules tri and 2x cat5e for the rest of the roooms
With the dish & aerial mounted to the rear stack it leaves me with about 10/15m of cable run before I can connect it to a multiswitch (being very generous with those numbers as I cant reach to measure :P),
The intent being to mount the switch in a cab on the middle floor in a windowless room/cupboard known as the home office.
(Sadly due to a few reasons this is about the best I can do, PE earth distance, power, ease of cabling)
The questions,
Can I get 28.2E astra2 and 28.5E EB1 off the same quatro or will I need 2 ? - you can use one, thanks for that robbo
what's the best way to ensure that the system is fully earthed to stop anything coming to haunt me after I leave this property.
(note, I intend to get a sparky in to fit the earth to the room.)
Will ct100 class cable be ok from the switch to the rooms?
Can anyone recommend 4 core and 2 core cables from the roof the switch? (I would like not to use 6 individual cables) - looks like the triax 5 core tx100 is the cable for the job and wf100 inside. - thanks for that robbo
Is 10/15m from dish to switch a tad too long?
I would like for the system to be bskyb compatible, I'm not a subscriber but it would be nice if it supported the digieyes and box's. I know that limits me to a few brands, triax being one, any others?
It would be nice to also feed a second/(third if you count the sky return) UHF source into the system for future CCTV/rf out's
Anyone know of any issues running multiplexed cables with cat5e in the same trunk ? If I understand the regs correctly even with a POE system installed its still legally OK but I'm concerned about quality.
Installation practice question, is it worth putting the dish and aerials on different masts or put them all on the same one ?
Anyone able to recommend brands and suppliers for the above kit?
Don't think I have forgotten anything, input anyone ?
EDITED: cleared up what sat's I'm after.
EDITED: Questions updated.
