LNB power and signal strength on different receivers
Old 21-06-2009   #1
My System: ASTRO Satellite Pay TV
my astro box the signal strength is about 58% whereas using my humax configured corerctly its only 24% so i cant even find any channels. Is it possible that the humax is under powering the LNB? There are 2 options for LNB power - standard and high. Im scared ill blow my LNB if i set it to high... this is for the same dish btw (by swapping the cable manually)
BaronVonchesto is offline   Reply With Quote
lnb, power, receivers, signal, strength
