Help wanted
Old 16-07-2009   #1
dallasboyes's Avatar
My System: pc running xp pro
Help wanted
I live in Tenerife
I have a SKY box with a freesat card but over here we cannot get BBC1/2 ITV3/4 so I have a set top box.
I also have a slingplayer on my PC which uses my flatscreen TV as a monitor, my problem is this
The TV has two scart sockets as does the SKy box and the set top box.
How do I use a DVD/HDD recorder which will record both the SKY and set top box.
Any ideas please.
PS I am a 72 year old pensioner so please not too techie
dallasboyes is offline   Reply With Quote
Old 16-07-2009   #2
Robbo's Avatar
Real name: Mark
If the TV has a third non SCART input, eg RCA/phono connections, maybe you could use that to view your DVD/HDD recorder.
Or you could use a SCART switcher on the TV input to select say between the Sky Box and the recorder.
Your DVD/HDD recorder will obviously need enough inputs to take the two sources you have.
The Following User Says Thank You to Robbo For This Useful Post:
dallasboyes (16-07-2009)
wanted
