you can feed 100's of flats if they are all feed from one smatv system.
how many boxes are you going to run??
3 or 4 boxes can be looped togeather and the output will feed the centralized amp.
lets sat one box bbc 1 one box bbc 2 another itv1 and another sky 1.
each box will have to be set up on a different channel.
leave 2 channel spacing.
first you need to see chat channels are free in your area.
example if a tv channel locally is uhf channel 21 another channel 30 another ch 40 another 50 you want to stay away from those channels
one box can be in this case on channel 23 another box 25 another 27 another 33 another 35 another 37.
problem is mains a power flop will make the boxes go to stand by.
a good computer ups 800 va may cost 150 euro and if you can get a global uk smc the smc will reset up to 5 sky boxes automaticlly.
you can set one for 101 bbc 1 one for 102 bbc 2 one for 103 itv1, one for 106 sky one and one for tv 5 105 if you want.
local channels as well as those you choose will be available at every outlet in the hole complex running of the same amp.
send me a personal message if you need more information.
been doing this for 21 years since the old analog days
ralph
