home upgrade
Old 20-07-2009   #1
eew
Real name: Barry
My System: basic sky box direct to main tv
Question home upgrade
Hello Chaps
Hope someone can help
I have a nine outlet old mercury telecraft tv-link system installed at home. 1 tv aerial feed direct from roof. All outlets fed in standard coax.
A standard sky box was installed at main lounge tv only. Sky box fed with CT100 direct from satellite, I have now managed to run additional 2 X CT100 to tv-link system and am looking to upgrade allowing TV and SAT in all rooms.
Can you suggest distribution unit and how to link from sat receiver?
eew is offline   Reply With Quote
Old 20-07-2009   #2
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
Welcome EEW,
It depends what you want to do. If You're happy with all outlets having access to what is on the S_y box then you could feed the RF output into a 'loftbox' type of unit like this in place of the Mercury unit...
_http://www.labgear.co.uk/products.php?action=showprod&cid=5&cname=IF%20Dist ribution%20Products&plid=16&sc1name=Home%20Distrib ution%20Units&sc2name=&pid=54&pname=HDU681S
If you want each outlet to have control over satellite then you'd need to consider a quattro LNB with a matching switch but you'd then need a receiver in each viewing location and cable to it from the switch
pgh13 is offline   Reply With Quote
Old 20-07-2009   #3
eew
Real name: Barry
pgh
Thanks very much looking at labcraft product now. Just working out cable connections!
home, upgrade
