Extending a normal digital aerial
Old 26-07-2009   #1
Real name: karen
My System: Cheap desktop computer from a supermarket with 1 Gb memory added, just normal TV and freeview set top box..nothing special
Question Extending a normal digital aerial
I've probably come to the wrong part of the forum for this question as I have no clue about this type of thing but here's my question anyway. I hope someone can help me.
I have a digital aerial installed on my home, which runs to a normal, straight forward digital freeview box. They are stopping the analogue signal in my area later this year so I have had an extension to the aerial run through to my eldest sons bedroom. I had to ring someone out and it cost me £45, which I think is a bit steep as the whole aerial itself and line only cost me £55 to have put up and installed for the living room. My question is this...is there a cheap ( and simple ) way to extend this new aerial line to my two other rooms upstairs, like some kind of adapter I can then run 3 ways? I understand I would need 3 different digi boxes.
Any advice would be grately appreciated.
karen is offline   Reply With Quote
Old 26-07-2009   #2
timbo86's Avatar
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn.
hi, You could fit an inductive 3 way splitter outside, or fit a 3 way f splitter behind your tv instead. Material would cost you around a tenner but its the 'labour' that is costing you. You could very easily carry this out yourself with the right tools,ladders and cable etc.
timbo86 is offline   Reply With Quote
The Following User Says Thank You to timbo86 For This Useful Post:
karen (26-07-2009)
Old 26-07-2009   #3
Real name: karen
Thanks timbo86. could you tell me exactly what to do, I assume you would need a good length of coax and if I went to an electrical shop would they know what I meant if I asked for a 3 way f splitter? Are there lots of different types? It needs spelling out to me I'm afraid as I am completely in the dark here. I am competent enough to wire something together if instructed, I fall short on the knowledge of equipment.
Old 26-07-2009   #4
satelliteman's Avatar
Real name: Paul
A splitter will only be ok if you are receiving a high enough signal at source to cope with the losses on each splitter port/cable run.
satelliteman.
An Installers Choice
Follow us on
Old 26-07-2009   #5
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4
Getting someone to visit your house and do some work for that amount sounds incredible value for money.
Huevos is offline   Reply With Quote
Old 26-07-2009   #6
kenny1234's Avatar
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn.
Dependant upon your area's reception you may find you need to use an amplifier-of some kind to distribute the incoming signals effectively to all the tv points you require
I agree with Huevos £45 for a room extension is good value for money.
kenny1234 is online now   Reply With Quote
Old 27-07-2009   #7
Real name: karen
I suppose the price is reasonable, it's just I only get £120 a fortnight to live on so I am trying to find a way of doing this at ultra bargain price. So, you all reckon it wouldn't be worth trying to do this myself? The best way would be the £45 guy?
aerial, digital, extending, normal
