Help! Sky Around The House, FreeSat in each room
Old 27-07-2009   #1
Real name: Paul
My System: Zehnder DX65 in motorhome. Sky Minibox in motorhome. Sky HD in house
I wonder if anyone can help me determine if its easily possible and with what kit to do the following@
I have SkyHD+ which I wish to be able to watch and control throughout the house
BUT I also want to have FreeSat receivers in each of the rooms where the main sky box is not - i.e. to be able to watch Freesat as an alternative when the main Sky Box is being used to watch something people in the other rooms don't want to watch.
I had thought about a domestic distributuon system with the appropriate faceplates - but have not been able to find one.
When I contacted one retailer he suggested I would need an LNB for each feed - but I had hoped to be able to distribute the LNB feed around the house in its raw state to use with Freesat - as well as conventional TV (digital and analogue)
Ideally as I am not at all technical, can anyone offer help as to:
- the viability of what I propose using a distribution system
- any kit (distributer and face plates) that would work
- how to set it up!
Many thanks in anticipation.
Paul
paul10june is offline   Reply With Quote
Old 27-07-2009   #2
Robbo's Avatar
Real name: Mark
Freesat receivers in each room is the easy part. Depends how many rooms you want. Up to 8 single feeds you can use an octo LNB. More than that, you need a multiswitch and quattro LNB.
Don't know about multoroom Sky distribution and control, you'd use the RFout 2 I presume.
Old 27-07-2009   #3
Real name: Paul
Thanks.
Thats annoying - I wanted to try to avoid messing with the lnbs. its a shame there is no way of taking a single lnb feed and distributing it around the house. Thats life I guess.
Paul
Originally Posted by Robbo View Post
Old 27-07-2009   #4
Robbo's Avatar
Real name: Mark
Yes, not possible due to band and polarisation switching with the LNB.
It can be done with a Fibre optic LNB of course, but they are expensive.
The Following User Says Thank You to Robbo For This Useful Post:
paul10june (27-07-2009)
Old 27-07-2009   #5
Real name: Paul
Thank you.
P
freesat, house, room, sky
