Help for a new double sat project
Old 08-08-2009   #1
My System: offset 120 pc intel celeron
I leave in Cape Verde. I want to install 2 sat antennas to receive Nilesat 7º West e Eutelsat W4 a 36º East with 2 Twin LNBs in order to serve 2 different rooms in my house. Then I buy regular subscription to Multichoice Africa, AlJAzeera Sport and Showtime. The three of them utilzing Irdeto 2.
What kind of receiver(s) do you suggest me? A Dreambox or others?
What kind of Multicrypt CAM?
How could I see them in the two different rooms using a single subscription?
Thanks for the attention and the replies I hope to get!
samarcanda is offline   Reply With Quote
Old 08-08-2009   #2
Archived Member
You will need a master receiver with three card readers.
I have a Dreambox 7000S which has two card readers which can work with a software CAM emulator like CCcam, and it also has a CI slot which would accept an Irdeto CAM.
I think that the newer model 7020S has also this combination, but 7020S might also be obsoleted soon, if it hasn't already.
So, you can have this option for a master receiver with all the subscription cards in it, and have a simpler receiver like 500S as a slave receiver in the other room.
You can add HDD to 7020S in order to record programs.
You will need a router and internet and two Diseqs.
Alternatively, you can buy 4 500S instead, 3 for the master and 1 for the slave, but in this case, you will not be able to record.
Hope that other members can confirm these options, as I haven't done any in house signal distribution.
HB13DISH is offline   Reply With Quote
The Following User Says Thank You to HB13DISH For This Useful Post:
samarcanda (11-08-2009)
Old 08-08-2009   #3
Grimm Member
rick1980's Avatar
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500
You could do it easily enough with just 2 recievers. For example
Reciever 1 - 2 card slots with Multichoice and JSC
Reciever 2 - 1 card slot with Showtime
Now just create a C and F line between the recievers, for in house use the IP address of the box on your network, not your external IP or DNS. Use seperate ports for each box for example.
Rec 1
f: rec2 rec2pass
c: 192.168.0.10 13000 rec1 rec1pass
Rec 2
f: rec1 rec1pass
c: 192.168.0.20 12000 rec2 rec2pass
Remember to watch showtime on reciever1 you also have to have reciever2 powered up.
Hope thats clear
I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off!
rick1980 is offline   Reply With Quote
The Following User Says Thank You to rick1980 For This Useful Post:
double, project, sat
