hello,
what satellite will you be using?
first od all you will need a dish big enough to receive the satellite in question.
then you will meed a quatro lnb, the quatro lnb will have all outputs different
outputs are hor lo,hor hi,vert lo and vert hi.
these outputs will drive a multiswitch.if you want 10 channels then a 10 output multiswitch will be in order.
if you want more then a 12 or 16 output will in order.
your 10 receivers should have a modularor on the back, these modulators ar adjustible from channel 22 to channel 68.
each output will be on a different frequency and if you have local tv there then you want to use those as well you need a spectrum analizer to set this up.
if local tv there are 10 tv channels and 10 satellite channels there should be no problem.
if local tv are on channel 22,30,35,40,45,50.55,60,65
satellite modulators should be channel 24,26,32,37,42,47,52,57,62,67
if there are many local tv stations in the uhf range then you will have to buy 10 programable modularors that cost about 50 euro each and will operate in the 115 mhz to 300 mhz range and make sure the 10 tv's can tune in this range.
these mudulators have a side band so there should be about 14 mhz or 2 channels spacing.
if one mudulator is running at 115 mhz the next one should be at 129 mhz,
the next at 143mhz,157 mhz,next 171 mhz,185 mhz,199 mhz,213 mhz,
227 mhz,241 mhz, etc.
then the modulators need to go to a combiner so there will be some loss.
then the locat tv and the 10 new modulated signals will go to an amplifier for the hotel.
this will send all the local tv and satellite free service to every tv in the building.
every satellite receiver will have to be isolated when you progral them with the remote controll becase if you program onr they all move.
cover the front to the remote beam will not be received bu the others.or isolate the one receiver at a time.
this is something the average person will not be able to do without the correct equipment.
and some knoledge on smatv systems.
this is a breaf discription on how this could be set up.
all the equipment is in a cool room of well ventelated of with air conditioning.
it will get hot in there.
ralph
bulgaria is too far from naples to set you up.
have a good day
ralph
