Originally Posted by NickNortham All,
Thank you for the prompt and helpful advice.
Last question - as I look at multiswitches - any pitfalls to avoid? As I understand it, I get a quad (or higher for expansion) LNb then a multiswitch to combine those signals with the terrestrial and send (ideally down independant cables) to each room.
Will all multiswitches be OK to combine the various sugnals? Is it just a matter of input/output connections?
Nick |
If you go this route, you require a quattro LNb to feed a multiswitch
(although there are some switches that can be used with quads).
5 input switches allow 4 satellite feed inputs (normally fixed) and a UHF/VHF feed. The multiswitch will deliver switched signals to each port/output.
Normally used if you require several Sat/UHF outputs. You can of course use upto an octo (8 port LNB) and diplex the uhf on one or two of the feeds along the line
