A friend asked me to make a hotel television system for his coming hotel opening next year. My planning is that I use 60 cheap satellite receivers with a composite or scart output and connect them to a RF modulator. The result is that I have 1 RF cable with 60 channels from the receivers.
For long distance RF cable to the room I use RF amplifiers, but I still looking for a 60+ RF modulator with bundles the signals to one RF cable.
This is far beyond the scope of the forum - you will need a properly wired distribution system using good quality modulators, installed by a company used to dealing with this sort of install..
Cant see how you can get 60 channels into spectrum of 48 rf channels though (21-69) even allowing for using every available channel.
Its certainly not an install you are going to be able to successfully do using hobby grade equipmnet.
