Originally Posted by morvanman Hi and thanks again for the info
Re the last but one post . I have a seperate LNB cable from a twin LNB to each box - no splitter.I also have a loop in the Humax box as recommended by the manufacturer if using only one feed. Still have this problem of limited channels with one feed. Is this not the set-up that is being recommended ?? |
No.
You will always have the problem of limited Channels with one feed, for the reason stated (It doesn't matter whether the you are looping through to feed one tuner in each of two boxes or two tuners in one box).
The set-up I recommended right back at the beginning was based on the assumption that at that time you already had two feeds (which is the normal position for someone with a PVR) and suggested a simple means of switching one of those feeds between the Humax and the
Sky Box.
Only later did it become apparent you actually only had a single feed initially!
Disregarding the
Sky Box, you will only ever have limited functionality on the Humax using one feed and the loop-through. Full functionality always requires one feed per tuner, so your Humax will only work in the limited fashion you've discovered.
rolf suggested instead that you upgrade to a Quad LNB. This would enable you to use two feeds for the Humax and another for the
Sky Box. Then, there would be no need for an A/B switch and you simply switch between boxes using the TV Source feature.
What you appear to have actually done is neither of those things! Not much has been gained and some confusion has occurred.
Anyway - onwards!
As you now have two feeds, you can either put up with the limited PVR functionality, or you can now get an A/B switch and do as I suggested earlier on (ie one feed permanently to the Humax and the second feed switched between the Humax and the
Sky Box, meaning full PVR function when the A/B switch connects the second feed to the Humax
or giving you limited Humax functionality but with the extra Channels you want available via your
Sky Box ), or you can get a Quad LNB and permanently feed all three tuners.
