Currently use a Pace DS445NB which I believe is a wideband receiver and this works fine for most free to air stations with a 1m dish
Connecting the DS445NB up to the one LCD using a coax cable is fine.
However I have a problem with the RF coax signal out when I need to distribute the signal around the house using a standard 8 way splitter
My previous
Sky box which wasn't wideband worked fine thro a 8 way splitter - is it a case of newer
Sky boxes are being produced which makes them less compatible with splitters ( and so forcing punters to buy additional
Sky boxes and use their multi room subscription ? )
If so I am on the look out for a good general purpose wideband receiver ( no need for
Sky plus ) which will work with a splitter
Can anyone recommend a good receiver which I will be able to pick up on
Ebay
thanks
