Hello!
and welcome on booard!
since when do you have this problem?
is your dreambox a clone or a orginal?
i hear often that clones,have sometimes problem,with the voltage output,for sending the diseqec comand,it could be to low,then the signal not transmitted proberbly to the swtich!
how long are the cables between the antenna?
and the dreambox?
i recocgneized,that some lnbs when there are older,and need to much power,then the newer one,make problems,on some swtiches,when the voltage level is getting to low,or the cables to long,often the problem is solved when you change the lnb,or the swtich,but first,please try to check,the voltage in a tv repair center,that comes out from your dreambox,when you have the posibility to use other receiver on your setup,you can check first,how it looks there,when is everything ok,your dreambox have a fault,if not,replace,that component,that you find out makes the problem!
good luck! |
