Hi There
I'm a bit of an amateur at satellite technology so thought I'd check for some help!
I have a sky + box with two leads coming in through two drilled holes in the wall, i want to turn this into a face plate (found suitable part on
Ebay
). At the same time I want a second face plate in a different area of the same room. This is only so we can move our TV if desired, we will only be using one
Sky+ receiver and one TV.
Its cosmetic only so if we move the TV we dont have to trail leads.
What splitters/junction boxes should i use/avoid? Can B&Q or
screwfix cater for the right of equipment?
I went to buy some parts but when I came accross 2W power passes and 4 band quad plexes - i thought it was worth checking!
Thanks for any help!
