Originally Posted by satelliteman Welcome to the forum,
It's feasible to use standard uhf coaxial but not recommended as this cable is normally only rated upto 1Ghz.
You say it's bigger, also you mention the cable supplying sky signal to your flat is dead. Can you elaborate on this  |
The signal can be traced to the cupboard in the communal area, but not from there to my flat. The engineer is suggesting that the only option is to run a new cable from the cupboard to the flat. But, this would involve running the cable through communal areas, out through the wall, along the external wall and into my flat.
This is costly and isnt going down well with the management company since it would have an unwelcomed impact on the communal areas.
So, i was wondering if the signal could be sent down the terrestrial tv ariel, since i dont need the terrestrial signal if i can get sky working again.
