Migrating from Sky to Free to air satellite ..Advice req
I have an old grundig sky box at present and want to change to a receiver which will give me free to air channels. Could someone give me advice as to the
best ones around and what kind to get i.e with cam slots etc.
I am looking for one around about £85 and I have a minidish set to Astra at present.
Any help appreciated or direct me to correct forum
My System: IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 21 years and is still driven by a modified wiper motor from a Ford Anglia. It's like me sometimes groans but always performs
If you are considering a new purchase then go for a unit that is well supported with patches such as the technomate TM 1500, and you can have cam slots as well. There is a full review if you click here. You would be better to change your s*y dish though. Your budget is the limiting factor though.
Formerly toppervte33h whose six pack has turned into a keg
Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button Thank you. Freddie Flintoff is back
I would be inclined to keep the digibox for FTV channels on 28.2 and set a separate dish and receiver for other satellites. As Topper says, the Technomate should give you a degree of future proofing, but may be a slither over your budget.
I suggest you read the extensive sections in this forum on setting up your dish and save your money. That seems a bit steep to me but what do I know???
